Tires tires tires tires tires tires tires tires tires
  • Tires tires tires tires tires tires tires tires tires
    UGH Tires!
    Every year I go through (this is no joke) 3 tires! And everytime I need to buy a tires, I have to replace the adjacent one also. This means 6 tires a year :(
    I never see a screw or puncture in the tire. I alternate cars in the winter, so therefore haven't changed my summer tires off the S4. Do summer tires have issues with winter driving? I.e. does winter temperatures cause them to have issues at the bead, etc? I'm looking outside and my tire is flat. Brand new tires from September still have the paint in the tread, already flat.
    If it is the bead, can I simply have them refitted?
    Also, what is the most affective way to determine the problem. I won't dare go to Kaltire and have my rim scratched by their monkeys. And booking time with Alex consumes my entire day. Who can look at my wheel and determine if I need to buy a new tire, or have it refitted or something?
    One time I had a cracked rim, and that was repaired (Also replaced the tires, which is how i found out it was cracked grr). But this is beside the point above.
    D.J.
    Turbo SVT Focus
    Audi S4 Stage 3++++++
    Re: Tires tires tires tires tires tires tires tires tires
    Bob @ Urban X?
      yah that's why i put this in his forum. i was hoping a reply from him............ eventually?
      D.J.
      Turbo SVT Focus
        You're better off to email him at bob@urbanexp.ca.
          Summer tires are made of a compound that does get harder when cold, and a harder rubber may not seal as well. Not always, but definitely tires will more often lose air in colder temps over warm temps. Is there any issues with corrosion on the beads of your rims? Assuming all is good and you haven't driven on the tire damaging it, resealing the tire should be no problem...
          Urban Expressions Wheel & Tire
          Bay #6, 1303 44th ave NE
          Calgary Alberta, T2E6L5
          888.769.1772 Toll Free
          403.769.1771 tel
          403.769.1773 fax
          bob@urbanexp.ca
            sweet! I hvaen't driven on it. if i bring my tire to you, will you make me another bacon wrapped sausage thing?!?! i'll give u a call tomorrow
            D.J.
            Turbo SVT Focus
              Hahaha! Bacon Bombs.... mmmmmmmmmmmm!!!! Those are actually Erik's specialty...
              Call me and we will set u a time to come in and get it looked at!
              403.769.1771 tel
              403.769.1773 fax
              bob@urbanexp.ca
                ahahahaha erik told me about those once!
                  **** you city of calgary
                  D.J.
                  Turbo SVT Focus
                    I was going to mention that fixa flat crap is corrosive and any chrome rim in the barrel part will rust. Rusting rims = holes which could leak air, first slowly, then fast.
                    Yikes, that is a bad crack. Was that a big name brand, stock or china stuff? Maybe your bad luck is over.
                      lol, it's okay .. what's done is done .. merely fustrating that this city is run by a bunch of old men who hire anyone who can hold a shovel from newfoundland to build our roads and don't know how to use steamrollers. packing the dirt on a repair with the back of a shovel is _not_ a proper solution ... but someone always gives some ******** excuse to avoid the truth by saying "blah blah blah too much snow" blah blah blah "no chinook" blah blah blah ... well, this isn't the first year we've had similar weather. WHICH btw to anyone willing to argue with me: we actually experienced normal winter weather this year!
                      anyway sorry, i am in a ranty mood tonight .. the manufacturer of this wheel is TSW
                      D.J.
                      Turbo SVT Focus
                        Well theres your problem now you can buy some nice wheels!!!!
                        or create a robot that paves roads correctly.
                        (Did you find your boost leak?)
                        2001 Audi A4 - RIP
                        2004 Mygale SJ04 - Racecar
                        2001.5 Audi S4 -SOLD
                        1986 Reynard SF86 -SOLD
                        2003 Jetta GLI - Garbage bin
                          oh yah roger i didn't tell you. the rs4 injectors i have are the skinny ones that require either the rs4 intake manifold, or the spacers. the problem is with my spacers. they aren't the 034motorsports ones. they are home-made machined out of a pipe (i think). not sure who's responsible for that, but they didn't cut a groove to fit an o-ring seal.
                          i'm surprised they had not leaked (much) over the past few years. every so often i run into boost leak issues, that i assumed were related to the intake manifold gasket.
                          thanx for letting me borrow your pressure tester. u can pick it up at cams anyday, if u haven't already.
                          byyyyyyyyyyyyyyyyy the way! i like tsw
                          D.J.
                          Turbo SVT Focus
                            I might as well jump in before anyone makes any conclusions about the injectors!
                            The owner of the car BEFORE me bought any random part that has 'RS4' written on it.. not having any idea if they fit or not, and he just told the shop to install them all. So with the car came some good and some bad....
                              youre the only one that likes TSW
                              Team Highschool
                              Twin Turbo Turbo Smurf Avant
