Just getting in some camber plates. These look to be the best on the market right now, extremely nicely designed and made.
If you are looking to make the front end of your Mk4 actually adjustable it doesn't get any better than this.
They would also look way better than any polished cap for some extra underhood bling.
Installs without drilling or strut tower modification.
Uses high grade spherical bearing and special load bearing top hat.
Two-way, fully independent camber and caster adjustment.
Gives almost 2 degrees over stock negative camber.
Replaces all factory hardware from the spring up.
These are going up for $450 a pair
