I had a lower tie bar installed a few weeks ago by recommendation from Paul at PG. I have been running for a while and really not being convinced of the benefit. However a loud creaking has been getting louder and I realised that one of the bolts was not as tight as it should be. After fixing that (a long story in itself) the difference in stiffness is definately noticable. Just reversing over the usual back alley slopes and gradients showed much less in-cabin squeaks and rattles; and I dont even have really stiff front suspension. Front end grip is a little better on the edge too. My guess is that those with race springs/ coil overs on the front will notice the improvements even more.
Lower Tie Bar
Tags: None
Re: Lower Tie Bar
Originally posted by Boy Racerone of the bolts was not as tight as it should be.Now is that bar the one that just looks like a round bar with flattened edges that goes under the skidplate? I have seen them before on the diesel geek site but never heard much about how they help, happen to have a price on them?
Re: Lower Tie Bar
Retail is $175, I can do some off for club members of course. It is an autotech steel bar, very strong and will no doubt help to keep that TDi sump off the ground too!
Originally posted by StonewallDid you use the same torque wrench Deuce used?Now is that bar the one that just looks like a round bar with flattened edges that goes under the skidplate? I have seen them before on the diesel geek site but never heard much about how they help, happen to have a price on them?
Re: Lower Tie Bar
Originally posted by Boy RacerRetail is $175, I can do some off for club members of course. It is an autotech steel bar, very strong and will no doubt help to keep that TDi sump off the ground too!KR
Re: Lower Tie Bar
It fits all MK4s
Re: Lower Tie Bar
Originally posted by Boy RacerIt fits all MK4sBut I am defintiely interested if you say it makes a difference, especially in the cabin creaks and so forth. Body stiffness = good. We'll see when I get back, once my reimbursement cheque comes in I was gonna order some stuff from ya anyhow.
Re: Lower Tie Bar
Simon, how much for club guys?
I'm interestedSteve
2002 Golf TDi
Whenever I see an old lady slip and fall on a wet sidewalk, my first instinct is to laugh. But then I think, what if I was an ant, and she fell on me. Then it wouldn't seem quite so funny.
Re: Lower Tie Bar
Do you also have a strut tower bar installed? Our cars are new enough to not need the reinforcement, but anything that helps reduce the creaks is good enough for me.
KhyronGeoff
Re: Lower Tie Bar
Originally posted by KhyronDo you also have a strut tower bar installed? Our cars are new enough to not need the reinforcement, but anything that helps reduce the creaks is good enough for me.
Khyron
