Coil over springs
  • Coil over springs
    I need 2 coil over springs for my 1999 vr6. They are standard 2.5 inside diameter. About 7 to 8 inches long. I need 2 to put into my to pass inspection. I need as soon as possible!!
    5878914152
    Sean
    Re: Coil over springs
    Sorry but WAY more information is required to be able to source these for you. Coilover brand & model / exact size & spring rates / part numbers are needed, as well as if they are on the front or the rear of the car
      The part number on them is 200-50. They are red in color, so I'm assuming they are h&r springs, they may not be... They are for the front of my 99 vr6 golf. As for spring rates I don't know. All I need is to get 2 to put in, to pass inspection. Than I will go and search out new suspension parts.
      Sean
        Check this directory
        http://www.hrsprings.com/applications/60mm_id_springs
