skid plates
  • skid plates
    i got my order of evolution skid plates in
    for the mk4 . i can get the units for the passat , and mk3 as well
    Re: skid plates
      Re: skid plates
      price??
      James
      mk4 wagon
        Re: skid plates
        290 + 45 install
        or 310 for unit with drain plug hole
          Re: skid plates
          Im guessing shipping would be problem with the skid plate? all the you need to install these is a tap and die set? or is there some sort of special tools needed?
          thanks again.
          James
          mk4 wagon
            Re: skid plates
            only takes me 15 min , i would include the install to club members
              Re: skid plates
              Hrm I think I'd drive out to Red Deer for that. I'm assuming that theres no point for the oil drain hole if you take your filter off from the bottom anyway? I read it's just 5 or 6 bolts to get the plate off when changing oil?
              Geoff
                Re: skid plates
                The riv nuts can spin over time (as I found out on one) unless you weld them after you install them. So the oil drain hole does save time and wear and tear.
                  Re: skid plates
                  hmm, well if you have to take the whole thing off to do an oil change. so no point in the old plug then?
                  and you have them in stock? no wait.
                  ill pm with a date i can make it out there.
                  thanks
                  James
                  mk4 wagon
                    Re: skid plates
                    The filter is taken from the top on TDI's so that is where the oil hole is the most effective. Personally I love my EVO plate and it has saved me many a time.
                      Re: skid plates
                      On my 1.8 I can only get it from the bottom (unless there's another trick), so I'm assuming the plate would need to come over over and over for me. I don't mind the extra step, just don't want bolts coming lose.
                      Geoff
                        Re: skid plates
                        the rive nuts would come loose because the threads would get corroded (spell check) and the oil change guy doing it would not put any anti sieze on the bolts also it dsent hurt to re torque the rive nut about evry third service ....if you have a 1.8 t no drain hole needed . you do need to remove it anyways yes
