well today when parking my car i got my bag out of the hatch/trunk and closed it, then hit the lock button on my key (2000 vw gti) and the lights flashed but there was no honk to indicate the car was locked, the 2 doors were locked but the hatch doesnt lock all of a sudden, anyone know how to fix or what i should do??
HELP : gti hatch wont lock!!!!!!!
Re: HELP : gti hatch wont lock!!!!!!!
i know its not quite the same, but my jetta sometimes doesnt lock when i push the button either. like others have said u gotta press open on the key then try lock usually works for me. and i know i need a new lock module thing i just havent had time to fix it.Justin
Does it latch? if it does and it doesn't honk it means you most likely have a bum microswitch in your latch. either way you'll be needing a new latch. unless you can find a microswitch.Like Type 2's? Visit my blog!
My posts and comments written here on this forum are on my spare time and are my personal opinion(s) and are not the opinion(s) or policy of my employer nor are they proven to be accurate. Use advice at your own risk.You dig sucka?!
Can you replace those switches Dave? I took mine out a while back (lock is pooched) and took a look at the switch, it doesn't look like it can be removed. Mine doesn't beep but it will after a couple minutes. One of these days I will get around to fixing it.Name: Brent
I know you can in the early Passat, all you had to do is remove the latch and take the plastic cover off and the switch is removable. As for the Golf/Jetta I'm having a moment. I can't remember if you can or not.Like Type 2's? Visit my blog!
It looked to me that the switch was between two riveted plates. It is also a slide switch so I am not sure on the type of switch it has inside. On another note though I have finally solved the starter grind issue and I am pretty sure it will not come back ever again, I should have taken pictures but I can let people know if they want.Name: Brent
Hi guys,
There's a good post on the vortex. If your car only doesn't lock when you close the trunk, then I'd say to replace the lock on the trunk.
Otherwise, if you have that problem and occasionally get a beep in the car while driving or the alarm goes off when you open/close the door, then you'll probably have to repair the microswitches in the driver's door or replace that mechanism.
Have a read...
http://forums.vwvortex.com/zerothread?id=1542461Last edited by dubCanuck1; 10-27-2006, 12:33 PM.1989 Golf Diesel (2001 TDI powered before teh apocalypse)
1992 Jetta TD
2001 Jetta TDI
1999 GTI resto
1996 AEB GTI project
