Every so often when I put my car into first gear, it ginds, what would cause this? Do I need to change my transmission fluid? Clutch?
First Gear Grind
Re: First Gear Grind
Are you putting it in first while the car is moving?Name: Brent
I say clutch. I've seen that alot. Your dual mass flywheel and clutch have seen better days..Like Type 2's? Visit my blog!
My posts and comments written here on this forum are on my spare time and are my personal opinion(s) and are not the opinion(s) or policy of my employer nor are they proven to be accurate. Use advice at your own risk.You dig sucka?!
Originally posted by StonewallAre you putting it in first while the car is moving?
Dave maybe onto something then, sounds crappy either way.Name: Brent
