I have a 2002 gti 1.8t and the owners manual says oil of 5w-40 is recammneded or 5w-30. As i did an oil change today i accidently put a 5w-50 in my car! should i be worried? should i rechange for the right stuff? or will it be fine? Fast advice please!!
Oil Help!!!!
Re: Oil Help!!!!
Was it 5/50 or 15/50? 5/50 will be a bit thicker at really high temps, which I don't think will harm anything (as opposed to being too thin). I would leave it and just use 5/40 next change.
KhyronGeoff
Re: Oil Help!!!!
5/50 is fine, some VW dealers use it. I would use it before 0/40 personally.
5/50: Exceeds all car and light truck manufacturer's warranty requirements for the protection of gasoline, diesel and turbocharged engines where API SM, SL, SJ, SH, CF or CD is recommended. Exceeds European ACEA: A3, B3, B4; Ford WSS-M2C931-A and the engine protection requirements of GM 4718M, ILSAC GF-4 for API Certified Gasoline Engine Oils.
KhyronLast edited by Khyron; 04-23-2006, 09:22 AM.Geoff
Re: Oil Help!!!!
Make sure you use synthetic. 1.8t's have a tendancy to sludge up with mineral oil, and that my friend is bad news for your engine and turbo.Like Type 2's? Visit my blog!
My posts and comments written here on this forum are on my spare time and are my personal opinion(s) and are not the opinion(s) or policy of my employer nor are they proven to be accurate. Use advice at your own risk.You dig sucka?!
Re: Oil Help!!!!
If you check Castrols site, they list 5/50 as a suitable oil for the 1.8, along with 5/40. Vortexers have been using it for years, but if you want to dump 40+ bucks, so be it.
KhyronGeoff
Re: Oil Help!!!!
Ryan had that put in his car by accident, they offered to change it but he was going ot park the car soon anyways. There was no problem with leaving it in there.Name: Brent
