MKIV Wheel Help
    Re: MKIV Wheel Help
    yea volks are HOT.. kinda pricey tho..
      Re: MKIV Wheel Help
      There is a set of Axis Se7en mods for sale on beyond, gimme a sec and I'll post up the link. I think they are like offset +42 or something so you should probably run some 10mm up front with maybe some bigger ones on the rear to push them out.
        Re: MKIV Wheel Help
        here you go:
        http://forums.beyond.ca/showthread.p...hreadid=111099
        • #19
          Re: MKIV Wheel Help
          sent him a pm, that might do the trick if I can just run some spacers with them to push em out a bit...
          • #20
            Re: MKIV Wheel Help
            yes, you can run 42mm with spacers (10 mil will get you a 32 offset), the one drawback is you will lose some lip on the outside (especially if you got the ones nismo posted up because they are only 7.5" wide). Also, I think unless you get them for a REALLY good deal it's not worth it because you will have to buy bolts and spacers which will add a few hundred to the cost, and it's always nicer to have wheels that "just fit" without monkeying around. The one exception is running Porsche or Benz wheels where adapters are required, I have no regrets on that.
            • #21
              Re: MKIV Wheel Help
              djstorm: check pm
