I was driving home today, and my little engine symbol (check engine) came on all the sudden. I was just thinking....I did an oil change myself at 49900km (that was the "next oil change" marked on the windshield) (P.S. This is my first oil change I've had to do since buying the car). The odo's at 50,450km now. Does that light come on at regular intervals like "around 50,000km" or should I take it in to get diagnosed? If not, how do I shut the damn light off? Thanks guys!
Engine Light!
Re: Engine Light!
Check gas cap - if it's not clicked it will set off the light. There's a few other things that are just flukes and it will go away after 4 or 5 clean starts. Emmision ones stay I believe. Get a scan from someone with a Vagcom if you can.
KhyronGeoff
Re: Engine Light!
Originally posted by KhyronCheck gas cap - if it's not clicked it will set off the light. There's a few other things that are just flukes and it will go away after 4 or 5 clean starts. Emmision ones stay I believe. Get a scan from someone with a Vagcom if you can.
Khyron
Oh, I thought of that...clicked the gas cap about 8 times...no dice. I don't know anyone with a Vagcom. Car's going in for a pan heater install tomorrow...may have to ask the stealership to check it out.
'02 Jetta 1.8Tuuurbo
--DUBS--
Re: Engine Light!
So I got VW to do a diagnostic run on my car while it was in for the pan heater install...turned out to be the engine coolant temperature sensor. $45 part and they didn't charge labor because it was such an easy repair. What a relief!'02 Jetta 1.8Tuuurbo
--DUBS--
Re: Engine Light!
Where did you get that done? The coolant temp sensor cost $7 both times I had it replaced and they charged me about $130 to install it, even though its like a 15 min job.Jeff
Re: Engine Light!
Originally posted by FlyBoyWhere did you get that done? The coolant temp sensor cost $7 both times I had it replaced and they charged me about $130 to install it, even though its like a 15 min job.
could'nt be at any dealership in Calgary,they will not install pan
heaters,and the same for Edmonton..45.00 dollars for the sensor
sounds like labor was built into the price..probably did'nt charge you for
diagnosis????/
Re: Engine Light!
Originally posted by FlyBoyWhere did you get that done? The coolant temp sensor cost $7 both times I had it replaced and they charged me about $130 to install it, even though its like a 15 min job.Derick
Re: Engine Light!
The old style blue plug sensors cost $45.Name: Brent
Re: Engine Light!
Originally posted by dubs_17Oh, I thought of that...clicked the gas cap about 8 times...no dice. I don't know anyone with a Vagcom. Car's going in for a pan heater install tomorrow...may have to ask the stealership to check it out.
Like Type 2's? Visit my blog!
My posts and comments written here on this forum are on my spare time and are my personal opinion(s) and are not the opinion(s) or policy of my employer nor are they proven to be accurate. Use advice at your own risk.You dig sucka?!
