Air Fuel Ratio & Boost Gauges On 1.8T
  • Air Fuel Ratio & Boost Gauges On 1.8T
    Im installing a boost and air fuel gauge today. Any tips would help. For the air fuel do I need to get a wide band O2 sensor?
    Mitesh
    Re: Air Fuel Ratio & Boost Gauges On 1.8T
    if you have an AWD engine, then you can tap onto one of the o2 wires (check out the vwvortex.com forums for more info). If you have an AWW/AWP code (2001+) then yeah you'll need another o2. I'd guess your guage is a narrowband one (0-1V) so you can just get a cheap o2 sensor and it'll work just fine.
    With regards to the boost gauge, here's my install!
    http://www.ottawa-vdubbing.com/forum...ic.php?t=13392
    1.8T
    Not quite stock anymore...
