I've a friend with a 2003 VW Jetta 1.9 TDI that's loosing power at higher rpms, in the lower gears its around 3000 rpm, in fourth its down to 2500 rpm, fifth won't maintain 110 km/hr on an uphill. He's run VAG-Com and no codes pop up, he's changed the MAF on-spec and still no improvement. Also, when he first ran the VAG-Com he received an error (maybe 1056) that indicated a coolant temperature sensor had intermittent problems, it's been replaced with a green updated sensor.
When it's cold the VNT rod moves freely, so it doesn't appear to be sticking...no word on when it's hot...because its hot!
The car also surges when on cruise at highway speeds, when watching the VAG-COM the boost doesn't vary any more than it should. Under full throttle he's getting about 230 kpa of MAP that drops suddenly at the rpms listed at the top.
Anybody have any ideas? Turbo issues? N75 valve(would you get a code)?
