i've tryed to max out the car and the fastest i get is about 149~150'ish before i loose all power, and the car feels like is drops into limp mode. is this normal for a diesel? if this is normal can i go faster...???
TDi top speed
Re: TDi top speed
something ain't right...in my dads TDI Jetta I've been up to 180kmh....and it was still pulling like a mofo. Of course this was ahem under closed track conditions.
Is your MAF ok?? I used to have the same problem back when my MAF was no good, couldn't get past 140ish if it was a life or death situation.Last edited by nismodrifter; 08-23-2005, 07:52 PM.
Re: TDi top speed
I had mine up to 185ish when it was still stock, peak speed didn't stay at that for long. I know Barts before he when turbo crazy, hit about 220ish on our banff cruize last year.Name: Brent
Re: TDi top speed
245 km/h for 15 minutes.Tach readings suggested true speed was around 235-ish. Used an obscene amount of gas.
Made it from McKenzie Towne to Lethbridge in 72 minutes. On a closed sanctioned McKenzie Towne to Lethbridge simulated track of course.
Oh, y'all were asking about TDI's. Just ignore this then.
Originally posted by StonewallI had mine up to 185ish when it was still stock, peak speed didn't stay at that for long. I know Barts before he when turbo crazy, hit about 220ish on our banff cruize last year.
Re: TDi top speed
Well ive got up to 180 as well, but the car isn't "Pulling like a mofo' per se, you're basically out of turbo at that point (I think its about4k rpm at 180) so its pretty sluggish, but 145 shouldnt be a problem, thats like...average highway crusin speed :PREAL men use harsh language as self-defense
-james
Re: TDi top speed
I would suspect that some larger tires to give taller gearing would help out quite a bit. I can't see the TDI running out of steam due a larger wheel circumference.
Too bad changing final drive gears is such a huge chore on FWD cars.
Re: TDi top speed
Originally posted by Hardy_Boyk well something is screwed then cause i can't get above 150 does anyone have any suggestions as to what it could be?
Dunno what it could be really.KR
