Hey - anyone have any advice on installing PhatNoise? I can't get the two couplers to go together. I know there's a "dummy" plug over the cd changer harness. I took that off, and I can't get the PhatNoise harness to click into the VW harness. The "male" plugs don't seem to slide into the "female" plugs. It's almost like there's something blocking them, but I can't see what's causing the problem. Anyone have this problem??
PhatNoise Problem!!
Re: PhatNoise Problem!!
Originally posted by dubs_17Hey - anyone have any advice on installing PhatNoise? I can't get the two copulers to go together. I know there's a "dummy" plug over the cd changer harness. I took that off, and I can't get the PhatNoise harness to click into the VW harness. The "male" plugs don't seem to slide into the "female" plugs. It's almost like there's something blocking them, but I can't see what's causing the problem. Anyone have this problem??
and charged me $89.00 because it was'nt installed by the dealership
good luck..diagnosis fee....
Originally posted by StampfanI had the same problem and had to seek help from someone else to make sure I wasn't going crazy. The trick was to wedge in one side first until it clicks, and then push hard on the other side to get it to click in.
I second that..Like Type 2's? Visit my blog!
My posts and comments written here on this forum are on my spare time and are my personal opinion(s) and are not the opinion(s) or policy of my employer nor are they proven to be accurate. Use advice at your own risk.You dig sucka?!
Don't feel bad . . . i wrestled with mine for about 15 minutes before I decided to bring forth the thunder within my mighty anacondas and make the harness fit.___________
Originally posted by dubs_17Got 'er in there. I opened up the female contacts a little with a pointed screwdriver...snapped in really easily after that!___________
is this an adaptor plug that you are talking about? or does the phatnoise plug righ into the vw cd changer harness? I want to get a phatnoise soon especialy sine the prices are dropping like bricks2004 Reflex Silver GTi 1.8t
1991 passat GT wolfsburg edition (euro spec)
1982 golf GTI (euro spec)
Autocross: the miniature golf of road racing
Yeah, the PhatBox cable plugs directly into the cd changer cable. SHOULD be a 5 minute install....however, with the troubles I had shovin' the two harnesses together, and the mounting screws not wanting to line up without some muscle, it took around 1/2 hr. It's really cool once you get 'er workin' and well worth the money.'02 Jetta 1.8Tuuurbo
--DUBS--
Originally posted by dubs_17and the mounting screws not wanting to line up without some muscle, it took around 1/2 hr.1.8T
Not quite stock anymore...
Anybody notice a static 'whine' with engine noise when the PhatBox is announcing something? I can't hear it over the music of course, but the quiet between songs makes it more noticeable.'02 Jetta 1.8Tuuurbo
--DUBS--
