Well, after replacing coil packs, spark plugs, some more spark plugs (after the replaced ones had the electrodes burn out of them), dialing boost and timing to sub stock levels with the SPS-3 I have finally solved my jerking/bucking/CEL/misfire/crap idle issue. It involved none of the above.
I removed the ground wire kit and >poof< problem gone.
I then replaced the plugs again with some fresh ones and it just got better.
Upon inspecting the wires I found no traces of cracking or wear, although the shielding was quite warped and discolored on the wires near the turbo (duh), and after removal one of the connectors popped off, but it seemed solid when it was attached.
Tomorrow I jack the boost back up from 12-13-ish psi to.. well.. a lot more, and continue my regularly scheduled program of driving like a crazed retard.
