So i'm minding a few weird brake things that I've never noticed before. One is that in the morning the pedal is hard (as though you pressed it several times with the engine off). Two, is that I seem to be able to overwhelm the system a little too easy, even when the car is running. Like 2-3 presses of the brake pedal with engine running and it is hard again, then slowly it goes down to the floor as it catches up.
I'm not sure what symptoms of a brake booster issue vs a master cylinder issue (and then I believe there is a servo in there somewhere too??) To me this seems like a vacuum issue with the brake booster. I checked the main lines to it for cracks, and all looks good. Solid vacuum up to the booster, and the check valve at the booster seems good. So if this is an issue, it seems to be within the unit.
Does this sound familiar to anyone? Does it make sense that this could be the booster?
