BRM Engine Code - 00361 Heater Element for Auxiliary Heater
  • BRM Engine Code - 00361 Heater Element for Auxiliary Heater
    My brother in law's 2006 BRM TDI has this fault code. Did some research and looks like the element could be toast. Any one have any experiences with this? Part is about $546 USD so going to do some more diagnostic work before replacing that one!
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element 0404
    Revision: 00800000 Serial number:
    Shop #: WSC 00000 000 00000
    VCID: 2D5B62FDB497C449F56-8078
    1 Fault Found:
    00361 - Heater Element for Auxiliary Heater (Z35)
    014 - Defective
    Re: BRM Engine Code - 00361 Heater Element for Auxiliary Heater
    Can check the main fuse as well run the measuring blocks if its not within spec it will need to be replaced
      Is the main fuse just in the normal fuse box?
        Should be by battery box. But I would need to double check
