Compatible parts?
  • Compatible parts?
    The TDI is diagnosed with a leaking oil return line. It is dripping onto the axle which is flinging it all over the car. Also looks like the turbo intercooler hose to the pancake pipe is fraying.
    ie: oil everywhere and weird turbo whistling noises! So good news is the turbo is fine.
    Want to get these parts from the nearby junkyard parts place but no TDIs. Do any of the parts form other models work (Like an oil line from a gti)?
    Re: Compatible parts?
    probably tdi specific but I can double check. you have the part numbers?
      Oil return line is 028145736AJ
      Hose not sure, maybe 1J0145838T or 06A145790A
        Oil return line is 028145736AJ - tdi only - bew and alh are the same
        Hose not sure, maybe 1J0145838T - this hose go from inter-cooler to egr - tdi only
        06A145790A - this is not showing up for me in the cross reference. But it looks like for 1.8 models only
          I figured.
          The pipe is the left piece of this picture. But I get the feeling it's going to be tdi only too.
          http://www.myturbodiesel.com/images/...mingbelt27.jpg
            I sent you a pm!
            Hers 2009 Audi A4 6sp manual
              If you are having issues finding a used one and are looking at buying new anyways this might be a better option.
              http://www.idparts.com/catalog/produ...oducts_id=1229
              2001 Jetta TDI GL Silver
