So I installed a Bilstein / H&R setup in my Jetta about 8 months ago. When I did my install I put in all new hardware (Bolts, caps, bushings and bearings) I ran the VR setup as I thought it would put up with the abuse a bit better. While I was doing the install I did a full cleaning of the wheel wells and there was no rust. I also Armor Coated the wheel well also. Being new to Alberta and learning how shifty the roads are I am re thinking my setup!!
Which checking my fluids and replacing a fuse from my stereo I noticed this!!!!
So what are you thoughts? Both sides did the same thing the bushings are OEM ones from the dealer. Call it a fluke or a failed part???
