So my girlfriends car started acting up, it seemed to go into a limp mode, and then it resolved itself and now it seems a little more permanent. I'm thinking something was loose and now its broke, what that something is, I have no idea. I am not the best with automatics. Now I have a friend with a VCDS who was helpful enough to give the car a scan this is the result:
Chassis Type: 9M (9M - VW Jetta IV (1998 > 2014))
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
75 76
VIN: 3VWSB29M42M016784 Mileage: 117080km/72750miles
Address 02: Auto Trans Labels: 01M-927-733.lbl
Part No: 01M 927 733 KQ
Component: AG4 Getriebe 01M 4892
Coding: 00000
Shop #: WSC 00000
VCID: 89171B82B39C7F564C9-0962
1 Fault Found:
00264 - Solenoid Valve 4 (N91)
36-00 - Open Circuit
N91 solenoid, I gave that the Ohm (resistance) test that was reccomended on vortex, came out with a reading of ~7.4ohms, and the acceptable values are somewhere closer to 5 ohms. I'm not sure if that is out enough to be worrying, or if my problem lies elsewhere. I gave a cursory check to the wiring that connects the TCM to the transmission, and it appeared to be in good order. I'm unsure of how to proceed, or what I need to look at next. Any transmission guru's want to help me out here?
EDIT: the initial measurement was when the car was hot. I rechecked after the car cooled down closer to the spec temperature, everything seems a lot closer. Does this mean that my solenoids are okay? What am I looking for if i am to trace the external wiring? Could it the the TCM..? Any way to do testing on that?
EV1 - 72.6
EV2 - 63.3
EV3 - 62.4
EV4 - 5.2
EV5 - 64.1
EV6 - 5.3
EV7 - Forgot to check lol.
TFT - 175 600
the spec at 20 deg C
EV1 - 55 to 65
EV2 - 55 to 65
EV3 - 55 to 65
EV4 - 4.5 to 5.1
EV5 - 55 to 65
EV6 - 4.5 to 5.1
EV7 - 55 to 65
TFT - 190 to 200k
75 76
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
EV1 - 72.6
EV2 - 63.3
EV3 - 62.4
EV4 - 5.2
EV5 - 64.1
EV6 - 5.3
TFT - 175 600
EV1 - 55 to 65
EV2 - 55 to 65
EV3 - 55 to 65
EV4 - 4.5 to 5.1
EV5 - 55 to 65
EV6 - 4.5 to 5.1
EV7 - 55 to 65
TFT - 190 to 200k
