Someone to lend a hand removing stuck oil filter Mk4
  • Someone to lend a hand removing stuck oil filter Mk4
    Hello I have a stuck oil filter on my 2004 jetta 1.8t and I can't remove it, I have tried an oil filter wrench and there isn't enough room for it so I went and bought the socket that fits on the end and it snapped and cracked. I'm just wondering if anyone has a better tool they could lend me or even lend me a hand in loosing it.
    Ill appreciate any help thanks
    I'm free tonight till 9
    I live in Cranston Far SE
    I will pm my address anybody intersted!
    Thanks
    2003 jetta 1.8t Wolfsburg Stage 2
    Sait AST Student
    Re: Someone to lend a hand removing stuck oil filter Mk4
    Take a screwdriver and pound it through the filter.
    What Engine?
      It's a 1.8t gas
      Sait AST Student
        Nvm I just got it loose after days of work!
        Sait AST Student
          Have you used the oil filter pliers ?
          I'm in Cranston aswell
          Edit guess I should read
          01 GTI -cammed+stroked
          06 gmc - duramax
          11 Touareg
          Can am renegade 800
            Might want to invest in a smaller oil filter wrench. I use this one, bought it at Walmart in the US for $2.50 and it works awesome. Fits a 1.8T filter perfectly with plenty of room to move the handle around. It's made by Fram.
            The screwdriver trick also works but can be a bit messy.
            Tyler
            vinylappeal.com
              Don't put the next one on too tight, you'll be reliving this last experience.
              GT3071R and more...
                Here's a tip to remove really tight filters, clean the filter, then wear pair of rubber gloves that you wash the dishes with, grab tight and twist.
                Current Fleet
                #ProjectICreate Jetta GLI32
                2001 Cobra #88/3786
                1989 Jetta Trophy 1 of 500
                Motorsport Engineer
                  http://www.metalnerd.com/cat17.htm
                  Part number MN7614. It works great. I borrowed it from Stefan a couple years back when mine was stuck, it worked a treat.
                  I bought my own and its a really useful tool to have.
                  http://imgur.com/It3qjSm
                  Current: 2002 Zonda CRV
                  2004 VW MK4 1.8T GTI
                    This did work great but be careful because there are pins on the top that connect the filter socket to the socket wrench adapter and when I give it to much torque with your hands to loosen it they will snap and be left with a piece of metal like me lol
                    Sait AST Student
                      If you are snapping off sockets with the shear torque of your bare hands, I'm not sure we can help!
                        the rubber dish glove .........Again this is great tip ..!!!!!.. also use the smaller filter(06A115561B) the added .2L is not needed in your non racecar situation .Not so tight also because you will disturb the oil cooler seal when removing with such force (this problem will surface in -20 when all your oil is on the ground)
