Help: 02M transmission rebuild info
  • Help: 02M transmission rebuild info
    Hey guys,
    Since the second day I received my car from the PO, third gear has been a bit choppy.
    When I'm doing hard acceleration if I don't granny shift from second to third the gear will grind, however short shifting or even power shifting any other gears have no problems at all. Because of this, I'm assuming the third gear syncro is bad.
    I changed the transmission oil about two months ago with OEM oil from ecstuning, but it still grinds if I don't shift perfectly.
    What I need help with is how to replace the first to second and second to third syncro on the 02M FSR transmission, I also need the parts number, I would also like to know what else I should do while I have the transmission off.
    Any help will be appreciated!
    July: still grinding.......
    Current Fleet
    #ProjectICreate Jetta GLI32
    2001 Cobra #88/3786
    1989 Jetta Trophy 1 of 500
    Motorsport Engineer
    Re: Help: 02M transmission rebuild info
    Have you tried adjusting your end links or checking any of the shifter bushings?
    Dylan
      No, I have no clue how to adjust them. The shifter bushings looked fine when I installed the R32 short shifter six months ago. Are the endlinks just the black thing with the spring that attaches to the shift tower? If so could you tell me how to adjust it?
      Current Fleet
      2001 Cobra #88/3786
      Motorsport Engineer
        Yeah I remember reading a DIY on vortex. I had some solid bushings you can buy from me if you wanna get rid of some of the sloppiness
        Dylan
          http://lmgtfy.com/?q=How+do+I+adjust+02M+shift+linkage
          TJ
          '17 Ram 3500 Laramie
          '01 Silver S4
            Thanks guy, I'll see if I need new bushings tmr and see if the adjustment will stop the grinding.
            Current Fleet
            2001 Cobra #88/3786
            Motorsport Engineer
              Learn to shift well?
              But adjust your linkages is the first step, undo the spring clips on top of the transmission housing, set the home positions then let the spring clips loose again. Easy, takes a few minutes.
              Next step to replace the synchro's is a decently big step, i would try to google other symptoms before i pulled the tranny
                Woke up early this morning to adjust the links, the third gear is not grinding normal shifting at 5000 However the second and forth gear seems stiffer than before, like it takes more effort to get it in slot.
                I pushed the shifter weight down and locked it in home position ,then locked the shifter down tightly, after that I pulled the two spring clip simultaneously then I release them. I didn't do anything wrong did I?
                Current Fleet
                2001 Cobra #88/3786
                Motorsport Engineer
                  Well its a good sign if you can lock both the shift turret and the shifter into their home positions without having to undo the springs. Normally if you require an adjustment you cannot do this, this leads me to believe that the linkages were adjusted correctly to begin with
                    Anyone else find it crazy that the OP wanted to rebuild a transmission but is having issues adjusting shifter linkage? Normally I'd say good for you for DIYing stuff, but a transmission is one thing you really need to know your stuff on to pull apart
                    Pat
                    His
                    Hers
                    2005 Porsche Cayenne S
                    Theirs
                    1977 VW Type 2 Westfalia
                    Gone
                      Awww give him a break Pat...I think he was looking at worst case scenario
                      Hers 2009 Audi A4 6sp manual
                        Haha, I didn't mean to be rude or anything... Hell, I'd be terrified of pulling my transmission apart.
                        Pat
                        His
                        Hers
                        Theirs
                        Gone
                          Haha, the adjusted it again then everything works like a charm.
                          Yeah, I was looking for the worst case scenario, I'm not afraid of taking things apart as I remember or take photos of where everything goes.
                          Thanks everyone!
                          Current Fleet
                          2001 Cobra #88/3786
                          Motorsport Engineer
                            Transmission rebuilding is a HUGE undertaking...that's why they're so expensive to get rebuilt...I'm scared $hitless of the thought of doing one.
                              We pulled Ryan's O2M apart....
