Seized ABS/speed sensor
Re: Seized ABS/speed sensor
Can't see your pics at the moment but what I did with my abs sensor a while ago was to unplug it then soaked the sensor with brake cleaner about 3x10minutes. Came off pretty easy on mine.Current Fleet
#ProjectICreate Jetta GLI32
2001 Cobra #88/3786
1989 Jetta Trophy 1 of 500
Motorsport Engineer
happened to me as well
just hammer/drill/break it out
just be careful not to damage the abs ringLast edited by Natty54; 04-01-2013, 06:34 PM.Now offering detailing services!! http://www.gtrauto.ca/detailing-services.html
Thanks for all the replies. I torched it a bit and it came out nicely. And drilled out the rest of the bolt. The old one had no plastic left on the end of it and the metal plates were bent to the side. I wish I kept it but I figured I didn't need it anymore. Now when I come to a stop, abs kicks in right before the car comes to a complete stop. Curious to your comment natty, Could the abs ring cause this to happen? or just a faulty abs sensor? The abs sensor light is gone btw.Silver Stoned
16' Lithium Gray F150( Winter mode)
03' 24V VR6
You could have bent the ring, but you also could not have done a good enough cleaning job before you put the new sensor back in. I have the same problem on the front, I didn't wire brush and clean everything good enough so the sensor sat perfectly the way it was designed.Ben
2016 Ram 3500 Laramie
2000 Jetta TDi, Dead and removing parts
2005 Passat Wagon TDi, 310,000 km's and counting, BSM delete done....Trans died going to replace
Her's
2016 Toyota Highlander XLE Pearl White
The cleaning I did the best I can. I ran a polishing bit through it after the wire brush, and made sure it was pretty clean. Also can antisieze affect it?
So I'm going to check the ring, I have a bad feeling the way the sensor was damaged, it may have bent it.Silver Stoned
03' 24V VR6
