02 1.8t jetta no first gear?
  • 02 1.8t jetta no first gear?
    So im driving around tonight and i come to a stop and try and put my car into first gear and it wont go in.
    Every time i try to put it into gear it feels like theres something blocking it. I can put it into any other gear?
    Any Help would be much appreciated.
    Thor
    -Terry
    -2014 S4
    insta:Whiney_S4
    Re: 02 1.8t jetta no first gear?
    Sounds like the shifting forks have gone...Collin/Bagged GLI and a few other guys here know quite a bit about this and should chime in.
    Hers 2009 Audi A4 6sp manual
      Before you do anything else, try a shifter alignment.
      http://vimeo.com/6881683
        It definitely doesn't sound like a shift fork if you can get it into second ok. It sounds like a shifter misalignment. For the time being you can try sliding it into the second gear slot before sliding it into first and see if that helps, sometimes it helps to align it for a temporary solution
          your headlight fluid is low
            Thanks for the quick replys guys ill check that stuff tommorow when i get home from school
            -Terry
            -2014 S4
            insta:Whiney_S4
              Yep what ^ said
              Mike
              '14 Toyota 4Runner SR5
              '04 Jetta Wagon 1.8T
                Correct. If you can get in to second then it might just be the alignment. There is a chance that the 1-2 rivet is cracked and giving out, but try the alignment first.
                Come see us for Sonax Cleaning Supplies, Parts, ECS Orders and General Maintenance!
                Follow us on Twitter!
                #7, 1115 - 48th Ave SE
                Calgary, Alberta
                T2G 2A7
                403-243-9661
                Info@CalgaryAutoworks.com
                  Well its decided im getting a new tranny and clutch in the jabba tommorow
                  -Terry
                  -2014 S4
                  insta:Whiney_S4
