Question on timing belt 2.0 turbo motor
  • Question on timing belt 2.0 turbo motor
    2008 passat 2.0 turbo. low km almost 5 years old
    What km or time is recommended for replacement of belt
    do you also replace water pump? reason
    are the factory ones still plastic like the older 1.8t
    what else should be replaced
    and what cost should one expect?
    dealer price?
    a/m shop price?
    or how hard is it for a DIY
    Thanks
    Re: Question on timing belt 2.0 turbo motor
    2008 . split engine year . FSI 110,000km.............................. TFSI chain ............
      if its TSI then 110k would be fine. While your in there, replace the belt tensioner (opt for a manual belt tensioner IMO) and water pump with a METAL impeller. There's little reason to do it other than to just get it done while your in there. Preventative maintenance is the best kind!
      Timing belts can be intimidating, but just take your time and triple check your work. If you do decide to do it yourself, im sure someone on the forum would be more than happy to help
