Need 83 rabbit engine running condition
  • Need 83 rabbit engine running condition
    Hey guys
    Working on a project need a 83 rabbit engine needs to be in running condition. I've heard That you can put a 1.8t in but anyone know forsure ?
    Thanks
    Re: Need 83 rabbit engine running condition
    Originally posted by Squire View Post
    Hey guys
    Thanks
    Lot of engine swaps are possible but only the original engine will just hook right up...
    Personally I have always wanted to put a 2.0 8v in a Mk1, I think that would be the best swap. Cheap, easy to find, easy to make run and run well (1.8t is always a *****), 120 hp or so should be fine in a Mk1 and not cause so many problems with other things breaking.
    Think this guy did it:
      I have a mk4 2.0 with ecu if you go that route. Pm/ text me if you need details
      01 GTI -cammed+stroked
      06 gmc - duramax
      11 Touareg
      Can am renegade 800
        Do a 2.0 swap, that would be fantastic
        '14 Chevrolet Corvette Stingray (On Order)
        '06 VW Jetta TDI (Daily)
        '07 Ford F-150
        '06 Mazda 3 (hers)
          Psst 2L is what I am putting in my cabby
            Also the route I want to go with my daughters cabby
              On another not the engine from my cabby will be looking for a new home but I likely won't get around to the swap for a couple months.
                2.0 aba bottom end with a 1.8 rabbit gti head. hold 8000rpm all day. high lift cam and some port work and it would make for a great little motor.
