Signs of OIL in splitter valve,
  • Signs of OIL in splitter valve,
    When i was cleaning my throttle body yesterday i noticed on my forge splitter valve on the opening for the atmosphere release
    there was slight signs of oil and not minimal but noticeable for sure, is it normal to have that amount of oil running from the turbo outlet, or should the turbo be sealed of oil the the turbine compartment??
    thanks
    Re: Signs of OIL in splitter valve,
    If your stock turbo it fairly normal, if you still have the stock smic there's probly lots of oil in there too You can take off all of the charge piping and clean with carb cleaner , except the rubber
    01 GTI -cammed+stroked
    06 gmc - duramax
    11 Touareg
    Can am renegade 800
      ive almost saved up for my fmic from natty so ill just wait till then but okay thanks
        What are you running for a PVC set up ?
        06 gmc - duramax
        11 Touareg
        Can am renegade 800
          PVC would be??? stock if anything
            Oil in your IC or throttle body is usually a sign that your seals are starting to go on your turbo...
              thats what i thought, but it pulls hard at 12 psi and no issues yet, just run her till she dies??
