Got a check engine light today...YAY!!!
  • Got a check engine light today...YAY!!!
    ****. So I got a check engine light today, not flashing. Solid. At exactly 191K...weird...
    Pat and I scanned it... this is what came up
    2 Faults Found:
    17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
    P1297 - 35-10 - - - Intermittent
    16825 - EVAP Emission Control Sys: Incorrect Flow
    P0441 - 35-00 - -
    The car drives exactly the same...any ideas what it could be? Did anyone pull these codes before?
    Re: Got a check engine light today...YAY!!!
    annnddddd you posted this why??
      Obviously to see if any one has had these codes in the past?
        quick google search revealed this top link: http://forums.vwvortex.com/showthrea...8check-D.V.%29
        Says DV valve, seems obvious, but try googling the other.
        Jess
          searching archives there are references to a bad N75, gas cap, or leak...sighh
            Do you have a factory DV?
              yes
                i would definitely guess DV then.
                Jess
                  Same code my dad got last weekend. Wierd.
                  Cleared his codes and havent come back.
                  Picked up a aluminum DV from Riegel Tuning for $115 just incase it pops up again
                  Pat
                  His
                  Hers
                  2005 Porsche Cayenne S
                  Theirs
                  1977 VW Type 2 Westfalia
                  Gone
                    the fuker went away
                      when its -30 and you get a code, i'd say clear it and see if it comes back and not worry too much. things don't move as quick as they should. pretty easy for something to be momentarily out of spec.
                      *wait.. "today" isn't today anymore - temp comment probably makes no sense
                        yeap, i know for next time not to freak out lol
