mk4 tdi check engine light
  • mk4 tdi check engine light
    hey guys, this is going to be kind of tough to explain but i'm going to do my best.
    i got a mk4 tdi and its chipped (by the previous owner) now i've found that when going full throttle in 5th gear the car goes into what i'd call "limp mode" at around 150. pretty much the power cuts out and it feels like my turbo shuts off. the solution to this is just to turn the car off and start it again and the problem is gone.
    i had been told that the problem is my throttle control censor..something to that effect.
    today i was on my way to edmonton and on the highway i went into limp mode so i pulled over, waited a few seconds for the engine to cool down, turned the car off and started it again and everything was fine, but now my check engine lights is on..
    any ideas as to what that may be? how bad could it potentially be to drive home like this? i'm not sure if i'll be able to get it checked out in edmonton or not.
    any input would be appreciated..
    thanks and happy holidays
    Re: mk4 tdi check engine light
    As long as its not flashing it will be fine to drive home. Get it scanned and it should tell you right away.
      Sounds like the exact same issues graemes been dealing with
      http://www.eurodrivers.ca/forums/showthread.php?t=20742
      Pat
      His
      Hers
      2005 Porsche Cayenne S
      Theirs
      1977 VW Type 2 Westfalia
      Gone
        Just don't go 150? Follow Graemes thread for possible fixes. When the same thing was happening to me though the turbo was on its way out, it tried to escape via the intercooler and failed...
          Sounds like it might be setting a over boost code. Mine has done that once before.
            what did you do to fix the problem?
              Fix to the problem that was described can be a few things. I had the same thing and would push the clutch in and turn the car off for a quick sec, turn it to on and let the momentum start the car.
              Over boost, could be a seized VNT actuator, or a N75 Valve. Mine was the N75, cost is not crazy and easy to replace yourself.
              MK4, which year exactly is it?
              Ben
              2016 Ram 3500 Laramie
              2000 Jetta TDi, Dead and removing parts
              2005 Passat Wagon TDi, 310,000 km's and counting, BSM delete done....Trans died going to replace
              Her's
              2016 Toyota Highlander XLE Pearl White
                When my mk4 did this, it was the turbo, but that was at the dealership. I'm thinking the dealer probably replaces the whole unit even if it is just the VNT actuator. All I really know is they replaced the turbo, but I don't know why.
                  Originally posted by benjamin View Post
                  mk4, which year exactly is it?
                  2000
                    Mine only did it once and it was a hot day and I was going 150+, It was probably due to the Diesel tunning box. If you have got a real tune I would agree that it is probably something wrong with the boost control or the turbo.
                      Kind of sounds like it is starving for fuel. Maybe not though.
                      2001 Jetta TDI GL Silver
                        You need to find out the exact codes, then report back.
                        If it is the throttle sensor, then it is easy to fix. The throttle is just a very simple potentiometer connected to the throttle pedal. Take the assembly out of the car (5 minutes), remove the cover over the switch brushes. Clean the contact strips and brushes, which normally fixes the problem. It is a very simple job.
                          yeah i need to get on that. gonna take my car to George to get him to take a look too. just so busy these days. the car's parked though until i get it checked out
                            I'd bet my last buck you are getting an overboost code:
                            16618/P0234/000564
                            === 16618/P0234/000564 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition) ===
                            The N75 valve is an open-shut thing. Power-on = open, power-off = closed. Variable nozzle turbo actuation is a graduated adjustment that goes from full-on to full-off and every adjustment in between.
                            How does a computer, and on-off mechanism, accomplish an infinitely adjustable range? It opens and shuts the valve quickly, and more quickly it opens and shuts it, and the longer the open pulses are, the more the turbo nozzle is actuated. Its the duty cycle, if the power is on 10% of the time the valve is open 10% of the time, and the boost is less. If the valve is open 90% of the time, the boost is more. So opening and shutting the N75 valve rapidly gives a variable amount of vacuum to the VNT actuator. There's a port in the N75 valve that allows vacuum to leak back in with the power off to equalize (leak-down) the vacuum. IF the actuator is rusty and stiff, if there's a leak in the old hard and cracked vacuum line, if theres extra carbon on the turbo vanes, if the VNT pivot shaft is a little corroded on its pivot, the system may not work right. There's your code.
                            The dealer solution is to replace parts until it works right, starting with the N75 valve, and going up to the turbo. It could be as simple as an old cracked vacuum line. Start there.
                            While you're under there replacing the line to the vacuum pot on the actuator, use a mity-vac to suck on the actuator, and see if it moves. If you can't move the actuator with the mityvac, the actuator is pooched. That was the problem in both of my ALH tdis, a 98 Beetle and my 03 Jetta.
                            There's a vendor (from Calgary I think) on this forum that will probably get you a VNT actuator for $150 or so.
                            The dealer solution for a pooched actuator will be $2k+ for a new turbo.
