1.8T Cleaning up the engine bay
  • 1.8T Cleaning up the engine bay
    So has anyone on here removed the SAI, N249, PCV, EVAP. Im thinking of cleaning up the bay for spring. Any input would be appreciated.
    In reference to this vwvortex diy http://forums.vwvortex.com/zerothread?id=3111538
    drive green ||
    Re: 1.8T Cleaning up the engine bay
    I have not, a few guys have on vortex and it would prob be a good thing to ask them since all the parts that came with the car are in a sense necessary but can be tweaked.
    I would love to do that to my car as well...but make sure in order for a cleaner looking bay that you will need to put in alot of work into it.
    Its worth it in the end tho imo.
    Originally posted by RedMile
      thanks, i know we don't have any law on emissions in alberta so with regards to that part should be alright to do. Im also flashed with Revo so I should be able to take care of codes easily regardless (after further reading simple ecu flashes do not get rid of cels, you'd need to have a BT file loaded).
      pics 4 clicks
      drive green ||
        the 1.8t engine bay is clean enough for me
        just look at a sti's bay and youll be satisfied haha
          I did it on my old car and didn't see any advantage, maybe was surprised to find a lot of gunk in there when taking things apart.
          Probably wouldn't do it unless you are on a BT setup or something.
            BT setup or something - soon enough ..
            drive green ||
              Ive anways wanted to do this> If you do end up taking these items out let me know how it goes. I wouldnt mind doing it myself too.
              James
              mk4 wagon
                Done it all . ..... removed evrything
                  don't forget to post pics of it when it's all done
                  drive green ||
