Cleaning engine bay
  • Cleaning engine bay
    I was about to clean my car, and realized my engine bay is quite dirty. So what should I use to clean my engine and is there anything on my 24v that I will need to protect?
    Paul
    take it to the pressure washer leave it runnig and pressure wash away... i did manmy times and no problems
    Dale Willimus
      awesome thanks
      Paul
        just make sure u have it runnig and use the presoak or the tire clean then rinse away and dry and detail as usual
        Dale Willimus
          I dont have any of those settings...i have a pressure washer at my place, it has two settings no soap, or soap...should I just pressure wash it w/o soap?
          Paul
            I use pressure soap and rinse -- then spot free -- works' great -- no problems at all -- and I've washed my engine bay more times then I can actually remember.
            Just make sure Paul, that you use the "lower" pressure setting on the washer -- you don't want to **** **** up!
            Peter
              either one works use soap then rinse....
              Dale Willimus
                i did mine yesterday.. just did the engine cleaner then rinse off and it worked great.. probably should simple green some of it though
