So I recently installed a Spec STG1 clutch and 16lb steel single mass flywheel in my car, as my stock unit was slipping pretty bad. Since the install the transmission is VERY noisy, particularly at idle in neutral. I've been told by spec that the noise I'm hearing is normal, due to getting rid of the dual mass flywheel, but to me the noise seems excessive. Does anyone have any experience running a single mass flywheel on a MK4? Is this noise normal or is something wrong? If this is a normal noise, this flywheel is coming out of the car ASAP! Please check out this short video I took of the car last night...
http://members.shaw.ca/mtennese/temp/noise.wmv
