Need help with camber plates
    Re: Need help with camber plates
    directional tire mounted backwards?
      Originally posted by Volkstech View Post
      But your camber couldn't be equalized the first time you came in for an alignment when you got the coilovers put on.. so I don't think it's the car or alignment techniques. It's probably something to do with the coilovers.
      Davey might be right,
      After rocken at C1 this morning They found nothing wrong with the coils, nothing bent nothing broken.
      So why is this ******** happening????
      Ken at C1 has teh same FK coils as i do. When he put them in his GTI everything was good ran straight, but later his car started pushing to one side. So to even things out he had to set his camber on both front wheels to .75 half of 1.5degrees. He sais everything is good, no more pulling to one side.
      So this may be a solution for me. F'en FK
      But does having camber on only one tire cause the car no to drive straight???
      Thats it ive had it, im buying a LADA
      12 VW Golf
      09 BMW 135i
      07 MKV GTI
      03 Jetta GLI
      01 Jetta GLS
      90 Jetta GL
        Dude, I knew nothing was bent. Here's your options.
        1. Get the camber plates and set the car up primo.
        2. Go back to stock suspension and try to set it up primo.
        3. Do nothing and buy tires every 20k and have a pumped arm from keeping it out of the ditch.
        All up to you my friend.
        Like Type 2's? Visit my blog!
        You dig sucka?!
