Hi everyone,
As some know, Al has bought my Jetta and it will once again be cruising around the great white North
So I've been addressing and fixing little issues with the car so that it's in grade-A status when he takes possession. I brought my Jetta ('02 1.8T) into the dealership to have a surging problem fixed. The problem is that when I'm accelerating, it feels like the power momentarily drops for a second, and then picks up again. With steady and hard acceleration, this pattern continues through the rpm range, although it is most noticeable around 4200rpm. Basically, it feels as though I'm taking my foot on and off the gas pedal during acceleration. VW ended up giving me the car back, basically giving up since they couldn't find the cause! I'm totally stumped and was hoping someone might be able to shed some light on possible causes. FYI the diagnostics came back totally fine and nothing was showing up on the computer to indicate a problem. I thought it was the turbo itself, but they assure me that it's in perfect form. The engine is also completely stock except for a CAI.
Here are the things VW tried, but these did not fix the problem (I'm sure I'm missing a few things)...
1) ECU upgrade
2) Replaced vacuum hoses and looked for manifold leaks
3) Replaced MAF
4) Replaced diverter valve
5) Replaced battery
6) Checked transmission controller
7) Checked air intake and hoses
8) Checked turbo
They cited the CAI as a possible cause and recommended I go back to a stock air box. I have my doubts it's the intake, but would appreciate everyone's feedback.
Thanks!
![Blink1](https://www.eurodrivers.ca/forums/core/images/smilies/blink1.gif)
1) ECU upgrade
3) Replaced MAF
5) Replaced battery
8) Checked turbo
Thanks!
