Car starter won't work after removing battery : (
  • Car starter won't work after removing battery : (
    My winter beater has a polar start car starter (or astro start.....not sure) that no longer works after I replaced the battery.
    Do I need to get it re-programmed?
    Does anyone here know how to do it?
    Any help would be great.
    Tint sucks
    Re: Car starter won't work after removing battery : (
    they are often installed with a disable switch (under the dash?) you can try switching that of and then on again?
    Eric..
      your thread title on it's own is hilarious my friend. AHAHAHAAHAHAH
      hmmm i wonder if the missing battery might be the problem
      2002 VW Golf GT TDI
        ahhh you actually mean the battery in the control not the car battery? Initially I thought you meant the starter motor in the car when youd had the car battery out!
        Dum dee dum....
        Eric..
          Let me clarify. I replaced the car battery, not the remote battery.
          After I replaced the old car battery, my car starter doesnt work anymore. As for the remote control battery, it is working fine because my keyless entry still works fine.
          Tint sucks
            Sounds like your starter is in "valet" mode. Locks work from remote but not the starter.
            If you still have the owner's manual for the remote starter, it will explain how to get out of valet mode, otherwise your best bet is to contact the retailer that supplied you with the starter.
            Jeff
            2006 Jetta TDI
            "If you think you don't like change, you will like obsolesence even less."
