So I was working on replacing my front brake lines with stainless steel ones to pass my OPI, and the connection on the old flex lines to the hard line on the caliper is all seized up. In my attempt to loosen it up I have stripped the nut on the hardline. (Yes I was using the correct tools, 11mm and 16mm wrenches).
Both sides are seized up at the caliper side connection of the flex hose, only one side has a stripped nut. I disconnected the fender liner side connection on both sides no problem.
Does anyone have any ideas on getting the flex line separated from the hardline? (I have already tried vice-grips)
Or do I just need to order new hardlines and cut the old ones out?
Any help would be appreciated.
-Matt
-Matt
