got the AR took in today for a repaint of both front doors due to rust under the door blades (weak)
anyways i got it home and decided to try and remove both blades to see if i can see how bad the damage is and i can even do some prep work myself
passenger side is OK and easy to fix
driver side is the really bad side.. i can't even get the door blade off.. 2 screws (one front/rear) plus 4 torxes in the middle
i can pull it out about oh 1/8" if that.. then i took a rubber mallet/cloth and hit it back in/ pull out/bash in/out to try and loosen it
i went and then sprayed liquid wrench into the crevice to it'll eat the rust away if anything is stuck there
ugh.. any other ideas to get it out? if the rust is really bad then i'm buying a new door from ebay/shokan and simply having it painted to match
ugh.....
ugh.....
