Need B5 rear brakes, ASAP, have any spares?
  • Need B5 rear brakes, ASAP, have any spares?
    Got into my 4x108-->5x112 hub swap, and on the rears it seems the offset is way off due to different rotor hat depth from b3-->b5.
    Using rear b5 hubs, so either a4 or s4 parts would work.
    Does anyone have any rear caliper brackets and calipers kicking around?
    Need to know asap, anyone who can pull through will certainly be compensated for their help.
    Cheers!
    Find me on Instagram @pry4sno
    Re: Need B5 rear brakes, ASAP, have any spares?
    What about rear A6 brakes, same as the S4, but the disc is solid not vented
      Have a line on rotors and pads, mostly just need the calipers and carrier brackets.
      Although, if you have a complete A6 set up I'm game
        Dont have any kicking around but I can get it.
        But by the looks of it the s4 and a4 calipers and carriers are different
          Thanks to Mike and Stefan for coming through with the local help-out. Now I can add calipers and dust shields, possibly caliper brackets to the pads and rotors previously sourced.
          Hm. I'll see what develops with these local parts on Tuesday and let you know if I need a hand. Thanks for the offer!
          Do you have an ETKA diagram that shows the brackets, or is it just a part number that's slightly different? Would love to know the PNs if you have them handy.
            The A4 carriers should be similar to the A6 carriers, the S4 carrier accounts for the vented/slightly larger disc
              A4 Caliper
              A4 Carrier
              S4 Caliper
                http://www.ebay.com/itm/VW-B5-Passat-Disk-Brake-Caliper-w-Carrier-PR-8E0615424-/290565763993?pt=Motors_Car_Truck_Parts_Accessories
                Does this seem right?
                I found a part number off vagcat for b5s4 rear calipers, and an ebay listing cross-referenced the same PN on a b5 Passat...
                Does this deepen my search field?
                  8E0615424C
                  Part number 4
                  Brake caliper housing
                  8E0615425B
                  Part number 5
                  Brake carrier with pad retaining pin
                    Found these rears on vortex, a guy was building a b5 and switched to b6 so I cash-in big time!
                    Total cost (used off VWVortex) shipped 4-5 day International via USPS ~ = to cost + shipping/duty of one new bracket from ECS.
                    Shokan wanted a core charge of $35 each, and still managed to be twice the cost!
                    Images supplied by seller.
                    Can't wait for the mail to arrive!
                      I think ^^^ will look just right perched atop these:
