Thursday,02,September,2010,21:45:55:53933
VAG-COM Version: Release 704.1
Data version: 20070723
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Mileage: 143030km/88874miles
Address 01: Engine Labels: 078-907-551-AZA.LBL
Part No: 8D0 907 551 B
Component: 2.7l V6/5VT G 0003
Coding: 06651
Shop #: WSC 06325
1 Fault Found:
17861 - Exhaust Gas Temp Sensor 1 (G235): Open or Short to Plus
P1453 - 35-00 - -
Readiness: 0110 1101
Address 02: Auto Trans Labels: 8D0-927-156.LBL
Part No: 8D0 927 156 BS
Component: AG5 01V 2.7l5VT USA 3132
Coding: 00002
Shop #: WSC 00000
No fault code found.
Address 03: ABS Brakes Labels: 8E0-614-111-EDS.LBL
Part No: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Address 08: Auto HVAC Labels: None
Part No: 8D0 820 043 P
Component: A4 KLIMAAUTOMAT D56
Coding: 00060
Shop #: WSC 06325
Address 15: Airbags Labels: 8D0-959-655-AI8.LBL
Part No: 8D0 959 655 G
Component: Airbag Front+Kopf 0002
Coding: 00304
Shop #: WSC 06325
Address 17: Instruments Labels: 8D0-920-xxx-17.LBL
Part No: 8D0 920 930 G
Component: B5-KOMBIINSTR. VDO D09
Coding: 02364
Shop #: WSC 00000
Address 35: Centr. Locks Labels: 8L0-862-257.LBL
Part No: 8L0 862 257 N
Component: CV-Pump D11
Coding: 16140
Shop #: WSC 00000
6 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
00956 - Key 2
09-00 - Adaptation Limit Surpassed
Address 45: Inter. Monitor Labels: 4B0-951-173.LBL
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06325
1 Fault Found:
01380 - Alarm triggered by Anti-Theft Sensor; Rear Left
35-00 - -
Address 56: Radio Labels: 8D0-035-1xx-56.LBL
Part No: 8D0 035 195 A
Component: Radio D00
Coding: 00117
Shop #: WSC 03030
1 Fault Found:
65535 - Internal Control Module Memory Error
00-00 - -
End --------------------------------------------------------------------------------------------------
little help on a couple of these would be nice, and possilbe reasons why? i can hear my locks leaking from in my trunk, an i know i need new o2 sensors, also did my front brakes and the warning light wont go off? how do i get rid of it? wasn't sure how to clear it with VAG
thanks in advance guys. the misfire on cylinder 3 has me worried. (not shown) i replace coilpacks and spark plugs as 107000km,
Coding: 06651
Shop #: WSC 06325
1 Fault Found:
P1453 - 35-00 - -
Coding: 00002
Shop #: WSC 00000
Coding: 00060
Shop #: WSC 06325
Coding: 00304
Shop #: WSC 06325
Coding: 02364
Shop #: WSC 00000
Coding: 16140
Shop #: WSC 00000
6 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00956 - Key 2
Coding: 00101
Shop #: WSC 06325
1 Fault Found:
35-00 - -
Coding: 00117
Shop #: WSC 03030
1 Fault Found:
00-00 - -
