So went for lunch and car started to misfire. No flashing or solid MIL so I kept going. Has been underboosting/misfiring for a while so figured problem would go away like usual. Nope.
It went from just misfiring to having no throttle at full input. Once a MIL flashed briefly and went out. Then I shut it down and restarted to gauge effect. Seemed fine then the issue repeated. After I tired to shut it down and go again the car just wouldn't catch.
Added a gallon of fuel (was actually on my way to refuel at the time), with no improvement. VAGd the car, cleared the codes, and swapped out CPs for different ones with no effect. Unplugged the MAF, no dice. It's getting spark and cranking fine but just won't start.
old guy from Audizine suggested it could be my fuel pump. Any chance the filter could be clogged and is dropping the line pressure?
Feeling out of my depth here... any suggestions would be appreciated.
