egt sensor problem
  • egt sensor problem
    ive spent all day trying to get the passenger side egt sensor put in, the threads on the sensor are fine, the threads in the mainfold look good, when i go to screw it in i can get 5 0r 6 turns by hand and only 2 with my wrench then it pops out. is there a chance the threads are not maching up? im not sure whats going on here. can i run the car with the sensor only a little bit in ? and is there another way or somthing i can use to get the sensor to stay in ? please help as i need the car for monday, thank you
    ps the sensor im installing is a used one i got from the classifields AZ. on my old sensor the nut got mangled and there were no threads on it.
    2016 VW GTI (Stock)
    2016 VW Jetta 1.4T (Stock)
