What does it mean when the "full" led on the vast watermeth is flashing?
w/m flashing led
Tags: None
Re: w/m flashing led
if it flashes as soon as the pump is set to start, it means that there is a fault, if it flashes under WOT, it most likely means full injection or at least borderline full injection. I have a feeling you are talking about a fault.I may appear to be nice, but don't be fooled, I probably don't like you
A flashing yellow led means that the controller is detecting an error.Jordan
Jerbel Autowerks
Distributor of parts from:
(403) 690-7135
jordan@jerbelautowerks.com
Lol I figured that much. Is the error in world peace? Sadness? Was it raped? no specific pattern for error codes?
Originally posted by aliencurv View PostLol I figured that much. Is the error in world peace? Sadness? Was it raped? no specific pattern for error codes?
Seriously, though, check the connections between the controller and: the meth pump, the +ve voltage supply (most likely at the 75X terminal on the relay panel), and the meth pump ground. Also try disconnecting the meth hose from the Y splitter and apply 12V to the pump and see if it's working.
Is the light flashing extremely fast, almost so that it appears to be a solid light? Or is the yellow light flashing in a very obvious way. If all of the above check out OK, then you may need a new controller. We can get yours replaced under warranty (hopefully it's still under warranty) for you. Just let me know what happens with your testing and we'll take care of it.
PS. You didn't respond to my message last night- jerk. hahaLast edited by The_Jerbel; 05-01-2010, 08:23 AM.Jordan
Jerbel Autowerks
(403) 690-7135
lol sorry i didn't even check the private msgs's until it was late. i was driving up as i sent it to ya from my cell phone.
u missed my buddy's 350 blew a head gasket or dropped a sleave last night. very very very very built motor and car. titanium bolts and the works. but 600+ wheel hp == distruction :( . he can still rock it, but the reseviour fills up. his exhaust smells so sweet lol
not much else happened. lots of cars came by, we shot the poop. talked about everything. my buddy linden, the bobsliegh driver for canada olympics who came in 3rd came by. we talked a lot about that and his experience; very very cool.
it was a good night, too bad u couldn't make it. next time i'll let ya know!
i'll poke around at the powers of the vast and see what's causing the error. i also blew another ignition coil last night. i had a competition against one of those srt minivans. just as i went WOT, boost cut, flashing check engine, 7 psi... still beat him lol!
Originally posted by aliencurv View Posti had a competition against one of those srt minivans. just as i went WOT, boost cut, flashing check engine, 7 psi... still beat him lol!
Sounds like you guys had a good time. Definitely let me know next time you're going up, and I'll try and clear my schedule. We've been so busy around here lately. We're currently in the middle of doing a Stage 3 build with a TIP to 6-sp conversion, we need to do another motor pull and turbo swap when we're done with that car, then we've got an RS6 S4 build to do after that, and then another K04 Stage 3 build with complete suspension component replacement after that. Everybody is waiting to get their car built, so we're trying to work double-speed to get everything done, without sacrificing quality, which means working over time.
It's important to take a few minutes to yourself every now and then, though, so I'll definitely try and make it up to check out Lightspeed with you next time.Last edited by The_Jerbel; 05-01-2010, 10:17 PM.Jordan
Jerbel Autowerks
(403) 690-7135
