Easy q for those who change their own oil
  • Easy q for those who change their own oil
    An easy question for those who pay attention while changing the oil on their turbo engines?
    Oil cooler design related=>
    The flange of the oil cooler has 3 channels/ports-one central port (outlet?) and 2 side ports (inlets?).
    Are the side channel/ports clear trough => allowing oil flow through both of them?
    Is the internal channel surface smooth or looks like a nut thread?
    Re: Easy q for those who change their own oil
    IIRC it is threaded. Never payed close enough attention. haha
    Kevin
    2000 s4, Custom vast stg2+, piggie pipes, ssac catback, evoms intake, 710n's, eibach sportline springs, RS4 Reps, VDO boost guage
      The internal port is threaded, and one of the side ports has a tab in it, the other is clear.
      Jordan
      Jerbel Autowerks
      Distributor of parts from:
      (403) 690-7135
      jordan@jerbelautowerks.com
        The tab was the reason I asked.
        Then everything should be just fine.
        Thank you Jordan!
        (I was looking for your response)
        Merry Christmas and Happy New Year.
        Dobby
          No problem
          Merry Christmas to you and yours, as well.
          Jordan
          Jordan
          Jerbel Autowerks
          (403) 690-7135
