2.7t problem .... surprise
    2.7t problem .... resolution?
    Got er booked in next week for a scan.Priced out o2 sensors.. $450 a pop lol.Didn't find anything about the egt's though. Anyone point me in the right direction for both, if those happen to be the culprits..
      Re: 2.7t problem .... surprise
      All vacuum lines appear attached and in great shape, no loose components found.Whats best method of doing a boost test.
        ask chris to call roger... if he has his tester still i'm not sure it could be down here atm
        • #19
          I dont live in red deer im a sask local there is a couple shops here that specialize in euro cars.Im guessing it takea specialized equiptment to perform the boost test?
          • #20
            Also can a scan pickup a bad o2 or egt even if its not throwing out codes.Weaker values or something along that line..
            • #21
              I can get you EGT sensors for MUCH less than your local costs.
              Yes, you need a little bit of special equipment to do a boost leak test. A euro shop should be able to do it though.
              Jordan
              Jerbel Autowerks
              Distributor of parts from:
              (403) 690-7135
              jordan@jerbelautowerks.com
              • #22
                Thanks man ill let you know what i might need next tuesday.Appreciate the help.
                • #23
                  No worries, good luck.
                  Jordan
                  Jerbel Autowerks
                  (403) 690-7135
                  • #24
                    thanks for the help guys you know them 2.7ts have two many cylinders for me lol
                    • #25
                      Ok back to the chipped 02 A6. Had it scanned today at a respectable european shop.Came up with code #P1602,1458,1460,1461.Code for EGR temp circuit.He cleared codes and reset adaption values.No pop ups after reset.He told me these codes have nothing to do with the driveability of the car all other sensors are operating perfectly, o2's all within same parameters.Also the car has had the factory air box removed and been fitted with a k&n cone filter.Thus the heat sinks that accompany the ignition control module have been removed(as they are attached to the factory air system) apparently there is air ducting to cool these sensors along with die-electric grease.Is this where where my car comes to fault?Module heating and causing my problems?But only after software was installed i had the problems?Im baffled.
                      • #26
                        Anyone got a factory airbox from there 2.7 biturbo?
                        • #27
                          Have you had the boost leak test done yet?
                          Jordan
                          Jerbel Autowerks
                          (403) 690-7135
                          • #28
                            **** i didnt even i totally forgot to even ask
                            • #29
                              I'm pretty sure I still have mine...PM me if you'd like
                              Kyle
                              2000 Audi S4
                              • #30
                                I have a couple of those airboxes sitting around. Let me know if you need one...
                                Jordan
                                Jerbel Autowerks
                                (403) 690-7135
