I chipped a guys a6 2.7t and after it has a wicked buck after 4000rpm hard acceleration . changed all the coils and plugs . any ideas . no codes
2.7t problem .... surprise
Re: 2.7t problem .... surprise
Boost leak test the car and scan for codes with VAG. I'm betting on a boost leak or dead EGT.Jordan
Jerbel Autowerks
Distributor of parts from:
(403) 690-7135
jordan@jerbelautowerks.com
I would check for codes with VAG. Not to undermine what Ryan is saying, but IME EGT's usually throw codes when they die, but not always. Also do a boost leak test.Last edited by The_Jerbel; 09-15-2009, 05:10 PM.Jordan
Jerbel Autowerks
(403) 690-7135
Did you log their output at all, just to see?Jordan
Jerbel Autowerks
(403) 690-7135
Sometimes it takes 30ish km's before the code appears, but it usually does appear eventually.Jordan
Jerbel Autowerks
(403) 690-7135
