I'm curious as to what ratio of water/meth seems to work best for you guys. Myself, I've found about 70% meth 30% water seems to work well. Also, do you find that the presence of steam and oxygenated combustion by-products (from the methanol) tends to skew your A/F readings a little to the lean side?
What kind of ratios are you water/meth guys running?
Re: What kind of ratios are you water/meth guys running?
A 50/50 mix works well. While I don't advise using it because of the flammability and toxic/harmful nature of it, 100% meth works best.
Meth injection will actually cause the A/F to run slightly more rich than without it.
More info on meth...Jordan
Jerbel Autowerks
Distributor of parts from:
(403) 690-7135
jordan@jerbelautowerks.com
I was running 50/50. But this time around i think im going to try some 60/40 meth/water.
Originally posted by The_Jerbel View PostA 50/50 mix works well. While I don't advise using it because of the flammability and toxic/harmful nature of it, 100% meth works best.
See, I'm not so sure that 100% meth would be best. The reason being is that: 1) you won't get as much combustion cooling/octane increase as you will with some water (which has an infinite octane rating since it can't combust) and 2) (If I understand correctly)When water undergoes it's phase change from water droplets to steam this produces an expansion which increases the cylinder pressures and results in more torque. I can actually confirm that my car pulls/feels stronger when I run closer to 65M/35W than at 75M/25W.
Here are a few of the articles that I've found which may be of interest:
http://www.max-boost.co.uk/max-boost/intake/WI.htm
http://www.3si.org/forum/f164/water-...tion-q-416206/ (I've seen this one on numerous sites)Last edited by Mister T; 08-16-2009, 10:46 PM."Paranoia is just the eerie sensation of knowing you're right"
The actual A/F ratio is decreased, and the measured A/F ratio readings also show up richer.
I'm just reporting what I've found to work best. I've used 100% meth and the IAT's as well as timing CF's were lower with 100% meth as opposed to a meth/water mixture. It's dangerous to run pure meth for a few different reasons, so it's a good idea to mix water in with it.Jordan
Jerbel Autowerks
(403) 690-7135
Originally posted by The_Jerbel View PostThe actual A/F ratio is decreased, and the measured A/F ratio readings also show up richer.
Also, in application I have found that Mohawk 94 oct E10 causes about a 2-3% positive deviation in my fuel trims vs non-oxygenated 91 oct."Paranoia is just the eerie sensation of knowing you're right"
Although most of it will burn, not all will. Like I said earlier, all combustion events will leave some trace elements which is why the O2 sensors are there in the first place. I guess what I'm getting at is that when you start adding oxygenated fuel to a combustion event, you are adding a disproportionate amount of O2 vis a vis straight gasoline and air. So the only way I can see the O2 sensors interpreting that extra trace O2 is that they would register the A/F ratios to be leaner than they really are."Paranoia is just the eerie sensation of knowing you're right"
Originally posted by Mister T View Postyou start adding...fuel....Jordan
Jerbel Autowerks
(403) 690-7135
Have you seen the differences using a 50/50 water/meth injection? Just wondering if the steam makes a difference."Paranoia is just the eerie sensation of knowing you're right"
I've noticed that the A/F ratio is richer while using W/M injection in a variety of different mixture ratios- 50:50, 70:30, 90:10, even using windshield washer fluid...Last edited by The_Jerbel; 08-18-2009, 06:15 PM.Jordan
Jerbel Autowerks
(403) 690-7135
Roughly 30% meth.Jordan
Jerbel Autowerks
(403) 690-7135
