I finally got tired of dealing with TIP issues, pulled the trigger on a used 01e to swap in, also found a buyer for my barely used (5k) TC which cuts costs almost in half. Pulling the engine and trans next weekend, should be up and running with the 6 speed wihin the month of July. plan to document this pull slightly better than the last one, wish me luck
6 speed swap
Re: 6 speed swap
Hey Ryan,
Sorry I missed your call tonight, I was in Transformers. As far as your question about the ECU goes, give me a call tomorrow so I can get a better idea of what you're referring to and we can figure things out. I should have the engine back in this car by next weekend, so if you need anything I should be somewhat available.Jordan
Jerbel Autowerks
Distributor of parts from:
(403) 690-7135
jordan@jerbelautowerks.com
Re: 6 speed swap
first 2.5 hrs went smooth, all fluids drained (or at least what isnt hiding in the block and turbos), intercoolers, airbox, rad support, rad, A/C, all out. Should be another 3-4hr and it will be out.I may appear to be nice, but don't be fooled, I probably don't like you
Re: 6 speed swap
Should be much less than 3-4 hrs to get the engine out from this pointJordan
Jerbel Autowerks
(403) 690-7135
Re: 6 speed swap
Originally posted by nothing77 View PostI'm slow,and I'm actually bagging and labelling all the nuts and bolts that come off this timeJordan
Jerbel Autowerks
(403) 690-7135
Re: 6 speed swap
Rob, the spare block is in the basement, has a 3.0l crank in it and not much else, funds permitting this should be done next summer, I'll stick with the stage 3 with 6 speed till next year. As far as heads go I may have Jordan send them to VAST to get worked. Jordan, I know your just givng me a hard time, i'll let it slide, considering I will be needing lots of help/advice once the 01e arrivesI may appear to be nice, but don't be fooled, I probably don't like you
Re: 6 speed swap
Located and purchased all necessary parts, found an 01e with 36k miles on it, total parts cost was about 3k cad with shipping. Nect week everything should arrive, with any luck I will be driving to Euroquake in the A6I may appear to be nice, but don't be fooled, I probably don't like you
