Re: Taking bets on the limp mode problem
the o2 sensor is used in "closed loop" mode. the computer uses the o2 sensor to determine stoich (which is 14.7 afr) during cruising .
if the o2 sensor is defective then cruising will be very rich and get bad gas milleage. but your WOT (wide open throttle) will be fine. during WOT, the computer goes to Open Loop which references a few maps to determine the final afr. WOT does not use the o2 sensor.
if there was a boost leak, then you would be running too rich. (unless the boost leak was affecting the charge pressure sender G31 and causing over boost). a boost leak would mean measured air was escaping when the computer expected it to be in the engine.
interesting thing i noticed while examining the monotronic programming and available senders tonight. it's interesting how the monotronic determines air density and humidity. the maf measures air in lbs/min as expected. then the monotronic knows the volume of 1 cylinder which it uses to calculate load. but interestingly, the G31 sender is referenced now to ensure the expected ammount of pressure is reached. if the pressure is too low (boost leak) then it will soft limp because it thinks the G31 or MAF is possibly defective.
so that's interesting that it can compare the two to determine "something is wrong". most pcm/ecu's have only one or the other. monotronic having two is awesome.
i dig that
i dig that
