After hours of work and not just a little frustration the engine is finally out. Big thanks to Jordan for coming by tonight and helping to separate the driveshaft and pull the engine with me. Now I can get to work on the TC, downpipes, exhaust, 02 sensors, new mounts, spider hose, and a couple of random things I broke while pulling it. Hopefully only looking at a couple of weeks downtime.
Engine pull
Re: Engine pull
primary reason is the TC, it is slipping under hard acceleration, giving me codes TCC stuck off. And yes turbo's are already K04, I just have to get the rest of the cars drivetrain healthy enough to handle full stage 3 power. Kyle those clips were forged by the devilI may appear to be nice, but don't be fooled, I probably don't like you
Re: Engine pull
Originally posted by Smarty39 View Postgood work Ryan...did you have fun with the clips inside the shifter box lol. If you need anything let me know
You just need to get the drive shaft out of the way and it's cake...Jordan
Jerbel Autowerks
Distributor of parts from:
(403) 690-7135
jordan@jerbelautowerks.com
Re: Engine pull
Originally posted by nothing77 View Postprimary reason is the TC, it is slipping under hard acceleration, giving me codes TCC stuck off. And yes turbo's are already K04, I just have to get the rest of the cars drivetrain healthy enough to handle full stage 3 power. Kyle those clips were forged by the devilJordan
Jerbel Autowerks
(403) 690-7135
Re: Engine pull
Details, I am upgrading the TC by having the stall speed increased by 6-700 RPM, TCU going in for stage 3 software, lots of engine cleaning and then some painting, ceramic coat painting the downpipes after they have been gutted and staight piped. Exhaust is out so I will most likely do a custom catback employing a crossover x-pipe and magnaflow mufflers, considering 2.5" and 3"Last edited by Mantis; 09-18-2008, 05:53 AM.I may appear to be nice, but don't be fooled, I probably don't like you
Re: Engine pull
Originally posted by nothing77 View PostDetails, I am upgrading the TC by having the stall speed increased by 6-700 RPM, TCU going in for stage 3 software, lots of engine cleaning and then some painting, ceramic coat painting the downpipes after they have been gutted and staight piped. Exhaust is out so I will most likely do a custom catback employing a crossover x-pipe and magnaflow mufflers, considering 2.5" and 3"
Re: Engine pull
Andrew, your full stage 3 will eat me alive, meth is great for keeping IAT's low, but it is no match for stage 3 powa. Still, let's line em up and see what happens. From what I hear yours should be purring again soon.I may appear to be nice, but don't be fooled, I probably don't like you
