battery replacement S4 in calgary?
  • battery replacement S4 in calgary?
    Anyone able to recommend a place to pickup a replacement battery for a 2001 S4 in calgary? Guess my factory finally decided it was wore out.
    I've tried Partsource /puke. and they have an undersized (dimension) that doesnt fit with the factory bracket. Anyplace that carries an optima or similar in town? or else a place to get a different mounting bracket for the battery?
    2011 Jetta TDI
    Re: battery replacement S4 in calgary?
    chris can probably get your an optima??
    turbo meyers on here.. das autohaus in red deer
    pm him
      Try Costo for the Optima. I think Audis use a group 35 Red top or D35 Yellow top just like the MKIV VWs. You might want to verify that first.
      2012 VW Jetta GLI
